Orbi WiFi 7 RBE973
Reply
RBS850 Orbi satellite's ring LED doesn't work
zen0701
The Orbi satellite's ring LED doesn't work. AC adapter plugged in power LED indicator turned on.
Performed reset to default, the Orbi satellite's ring LED still doesn't work.
Message 1 of 9
Accepted Solutions
Guru
Re: RBS850 Orbi satellite's ring LED doesn't work
Disconnect the RBR from the ISP modem/ONT. Conect 1 wired PC to the LAN port of the RBR. Disconnect all other LAN cables from the RBR.
Press the back reset button for 15 seconds then release. Observe the front LED. Does it turn ON and start blinking?
Message 4 of 9
All Replies
Guru
Do you mean the front LED?
It should turn ON and blink WHITE for a bit then maybe turn OFF...
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Message 2 of 9
zen0701
Yes, ring LED means front LED.
How can i know the satellite is up and running EXCEPT LEDs indications? becuase there's no LEDs turns on or pulsing white.
Not sure is firmware or hardware issue? i also tried Ethernet backhaul connection but still failed.
Is there any utility that i can use? i tried APP and login "http://orbilogin.com." but still unable to add / link satellite.
is there any way to upload/update the firmware to satellite using wired connection? becuase the satellite didn;t update the firmware quite long.
thanks for helping me out.
Message 3 of 9
Guru
Message 4 of 9
zen0701
RBR is working well, the issue is on RBS. i tried many times on reset RBS but still doesn't help. thanks.
Message 5 of 9
Guru
Whats the LED on the back of the RBS look like? RED or GREEN?
I presume the RBS does not appear in the RBRs web page after you turn it one and it attemps to connect?
Try swapping power adapters as well to see if this changes anything...
Message 6 of 9
zen0701
Whats the LED on the back of the RBS look like? RED or GREEN? Ans: solid RED
I presume the RBS does not appear in the RBRs web page after you turn it one and it attemps to connect? Ans: Yes.
Try swapping power adapters as well to see if this changes anything...Ans: Yes, i tried but doesn;t change.
Message 7 of 9
zen0701
I googled that realized
RBS850 bricked. Power LED flashing red on satellite
Blinking red. The firmware is corrupted. shoot....
Message 8 of 9
Guru
You can try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
https://www.thewindowsclub.com/enable-tftp-windows-10
if any of this fails, make contact with NG support and ask about yoru options and RMA.
@Blanca_O
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1395 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
