- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850 Satellite keeps flashing white (seems to operate correctly)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since a day or two, the satellite of my Orbi system keeps flashing white. It indicates that it is trying to restore factory reset settings (but what triggered that?) according the docs.
Logging into the system, the administration pages indicate that the backhaul connection is good. Also devices connected to the satellite seem to operate as they should (from connectivity point of view) both 5G and 2.4G connections.
I did power cycle the satellite a few times but the flashing problem persists.
Note I have seen articles related to firmware upgrade on this issue but the firmware of both router and satellite are up-to-date v3.1.5.23 according app so they haven't started an automatic update (although there is a newer one on Netgear support)
Hans
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know. Be sure to make a backup configurtion to file for safe keeping. Saves time if a reset is needed.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS850 Satellite keeps flashing white (seems to operate correctly)
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try updating FW on both RBR and RBS:
Factory reset and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is not about the distance: that is ok (it worked for >=12months) without major issues.
I finally managed to stop the flashing by redoing a firmware upgrade.
It seems that the ability to connect to devices was not affected by this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
