Orbi WiFi 7 RBE973
Reply
RBS850 multiple vlan support
Matt40uk
Follower
Hi All,
I’m trying to find out if the RBS850 range supports multiple vlans?
The videos I can see online sometimes show vlan options in advanced setting at the bottom, but I don’t have that.
Does anyone know if vlan support is coming?
Thanks
Matt
Message 1 of 3
Guru
Re: RBS850 multiple vlan support
Not the RBS. The RBR has some VLAN support is all. Only 1 I believe.
Message 2 of 3
CrimpOn
Guru
Orbi routers do not support VLANs in the sense that most of us understand. (separating devices from each other).
Some ISPs require customers to activate a specific VLAN to support IP televisions.  This is the capability that Orbis support.
See page 75 of the user manual:
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 595 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
