Reply
RBS850 only 2 when i have 3
WDxDangermouse
Follower
Hello.. I installed 3 Orbi set.. One connected to my modem, and the other 2 around the house. When I log into the Router admin mode on my desktop it only shows 2 units under connected Satallites... Is this normal for Orbi or should it show all three? Being called Satellites, I assume its correct, but you never know Smiley Happy
Cheers
Message 1 of 4
Guru
Re: RBS850 only 2 when i have 3
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 4
Guru
Only the two RBS will be displayed in the Satellite section of the RBR. The RBR is not a RBS.
Testing
Message 3 of 4
schumaku
Guru
Perfectly normal - the router itself is never a connected device. Satellites, mobile phones, wireless notebook, tablets, ... are among many others.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 175 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
