Orbi WiFi 7 RBE973
Reply
Red LED always on in AP Mode
kinsham
Tutor
I use my RBR350 in AP mode. The status LED is permanently red after boot up which I presume is because there is nothing connected to the WAN port. There doesn't appear to be any way to turn this LED off. I would have expected that the LED would always be off in AP mode since no connection to the WAN port is normal.
The status page shows internet connection is good. Is this a firmware "bug"?
Message 1 of 4
Accepted Solutions
Guru
Re: Red LED always on in AP Mode
In AP mode, you should have the wan port on the RBR350 connected to your router
Message 2 of 4
All Replies
Guru
Message 2 of 4
kinsham
Tutor
Thanks for that. I hadn't realised that. I had thought that the WAN port was only for a modem connection. I switched it over and now the light is off and Internet is good. As a bonus i get an extra port on the RBR350.
Message 3 of 4
Guru
Glad to see its resolved!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 868 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
