Orbi WiFi 7 RBE973
Reply
Sattelite question
xduyck
Follower
Sattelite question
Hi, do I need to connect the sattelite trough an RJ45 as well or does the sattelte box connects to the router trough the wifi ?
Message 1 of 2
Chuck_M
Mentor
Re: Sattelite question
Satellites backhaul to the router in one of two methods.... wired or wirelessly.
Wirelessly is most certainly the more common method -- and typically works right out of the box.
Orbi has dedicated internal radios to perform this high-speed backhaul.
You can, however, use a wired connection, based on your own scenario (perhaps the wireless backhaul cannot reach the satellite).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 351 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
