Orbi WiFi 7 RBE973
Reply
Serial or Star setup for Orbi 960 Wifi 6E
colst03
Tutor
Hello,
Is it possible to setup the satellites in series or only in star configuration ?
for example if we want to cross a long distance.
thanks in advance.
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi 960 Satellite - Cable Connection ?
Yes and yes:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Message 3 of 4
All Replies
colst03
Tutor
Hello,
Is it possible to connect 2 Orbi 960 together using a RJ45 Cable ?
Thanks in advance.
Stephane.
Message 2 of 4
Guru
Yes and yes:
Message 3 of 4
colst03
Tutor
Thanks
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 767 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
