Reply
Service unreachable
asmc
Service unreachable
orbi 852
same problem whatever old version or latest vesion fireware
Message 1 of 6
Guru
Re: Service unreachable
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
@asmc wrote:
orbi 852
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router R7960P (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 6
Guru
I see NG just posted v10.11 acutal files for download:
https://kb.netgear.com/000061769/RBR850-RBS850-Firmware-Version-3-2-10-11
You may want to download these and apply them manually using IE11 or FireFox. I highly recommend a factory reset on the entire system after the RBS and RBR have been updated with these files. Power OFF the ISP modem/ONT for 30 seconds then back ON. RBS first, then RBR lastly. Set up from scratch.
Message 3 of 6
Guru
Got word from a forum moderator. NG will be removing v10.11 from there update servers and from the support site. NG is still working on this. Please be patient.
Message 4 of 6
asmc
thank you answer me, expect NG to fix it soon
Message 5 of 6
Guru
We hope so too.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1173 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
