Orbi WiFi 7 RBE973
Reply
Slow speed on RBS750
KD4200
Hello,
Im experiencing slow speeds when connected via cat6 to my RBS750. This satellite is wirelessly connected to the RBR750. I have went though talking to support and even exchanging the units as they (support) deemed them as "defective". I am only able to get around 200-230mbps (on the "defective" units and the current units). Wireless devices connected to the RBS750 such as my iPhone 7 pull faster speeds (260-280mbps), my wifes iPhone 11 Pro max is even faster at 300+mbps. I have changed settings such as transmission power, CTS/RTS, preamble, etc. Regardless of the setup - i can never get faster speeds then stated above with devices connected via ethernet to the RBS750. Also, I have a 2018 iMac 21" connected via WiFi to the RBS750 and that is getting the same speed as the one connected via ethernet. Furthermore, to make sure the RBR was centrally located I personally made a cat6 drop in my home directly from the ONT. Tried multiple cat6/cat5e cables and ethernet dongles. Results are always the same.
Current setup is
Fios ONT (cat6) -> RBR750 -> (wireless) RBS750
CTS/RTS: 2347
Transmission control: 50% (Tried lowering transmission control thinking that the RBR and RBS signals were conflicting but that didnt do anything)
unchecked Enable 20/40 MHz Coexistence
Premable: Short
Message 1 of 11
Guru
Re: Slow speed on RBS750
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 2 of 11
KD4200
3.2.18.1
Black box fios ONT. not sure if the specific model but it is the newer kind of ont.
2100sqft
Approx. 25ft. RBS is upstairs and the RBR is downstairs.
2.4 channel 11 (2 other people on this channel)
5 channel 40 (no one is on this channel in my neighborhood).
6 that I can see through WiFi analyzer but their signal strength is weak.
Message 3 of 11
Guru
So turning OFF the RBS, what are you wired and wireless speeds with your devices connected at the RBR?
What CTS value is on the RBR?
25feet is a bit too close. 30 feet or more between the RBR and RBS is recommended.
Do you have any AX mode supporting devices?
Message 4 of 11
KD4200
I will try turning off the RBS and checking WiFi speeds with the RBR when I get home.
As for the router and satellite being too close, I lowered the transmission control to 50%.
All values above are current configurations for the router. NG doesn’t allow for configurations of the satellites. CTS is 2347.
Message 5 of 11
Guru
Ok keep us posted.
Yes, only configurations are maded on the RBR. Any changes are pushed to the RBS by the RBR where needed.
Message 6 of 11
KD4200
Currently connected to just the RBR via wifi to a MacBook Pro 2020 with the satellite disconencted and only getting 20mbps down. I even turned the transmission control to 100% from 50% but still didnt help.
Message 7 of 11
Guru
Going to have you make contact with @Christian_R and ask him for access to the 7 series beta and see if this helps any. Kind of last resort and someting to try. I'm kinda leary of have you try the new v4 FW as I'm not sure if this will help and one thing, users can't seem to revert back from v4 to v3 FW  so rather not have you try this right now. If you can get the beta applied and see if anything changes. If not, then I would bet that the RBR is faulty and needs to be RMAd. Something to open a support ticket on anyways and get and going.
Message 8 of 11
KD4200
Honestly, Im having a hard time believing this yet another faulty Orbi. I dont  know - just seems *weird* to get two duds in a row. Not looking forward to running the same routine of turning off and turning on my Orbi's with support again. I guess ill just live with it at this point. First world problems.
Message 9 of 11
Guru
Understand man. I'm hoping new FW may change. Gotta try it.
Could be someting in your envrionment as well. Happens if you see this across two same model systems.
Message 10 of 11
Blanca_O
NETGEAR Moderator
Hi @KD4200
We'd love to give a hand and look into your case further. Please send me a private message with the case number so we can pull up your records and check what else can be done to have this issue resolved.
Blanca
Community Team
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1535 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
