- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow wired speeds connected to RBS750 satellite only when running through switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When coonecting directly to the sattelite (5 ghz backhaul) with ethernet (Cat 6) I get speeds of around 400 mbs. If I run it through a switch though I only get about 70 mbs. I've tried 2 different switches, both Gigabit one TP Link one Netgear.
Anybody have an idea why this is? Is there a setting somewhere I am missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Slow wired speeds connected to RBS750 satellite only when running through switch
If directly connected to the RBS is fast and then putting a switch in the mix results is slower speeds, I would presume these switches your using would ge the cause of the slow down. Nothing in any configuration that should change this. Either this is a switch problem or a bad cable or both.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, thanks for the reply. It's not the cables because I tested them. The switch is a brand new unmanaged switch from Netgear. I guess I have to try another one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok.
