Orbi WiFi 7 RBE973
Reply
Take a RBS850 apart, how to do that
Starky-50
I want a manual to remove the cover from my RBS850. One of the mounting points on the bottom has come loose. Does anyone have a description of how to take it apart.
Message 1 of 4
Accepted Solutions
Starky-50
Re: Take a RBS850 apart, how to do that
That will do.
thnx.
Message 4 of 4
All Replies
Guru
Look either at the back for front down under where the front white cover meets the front LED, There is a tab on the side on the back of the white cover. Press this towards the cover itself. Then I believe you gently push upwards and the cover should come off.
Message 2 of 4
CrimpOn
Guru
There are pictures of the case in the FCC filing for the 850:
https://fccid.io/PY319200453/Internal-Photos/Internal-Photos-rev-Part-1-4433134
Message 3 of 4
Starky-50
That will do.
thnx.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1145 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
