Reply
Unknown wlan0 devices on 2.4 ghz Orbi network
wap1
On my RBR750 router with two wireless mesh satellites (Orbi RBK752 system), I occasionally see two devices connected to the 2.4 ghz wireless network, and they are both labeled “wlan0”. What are these? Are they associated with the satellites? All other devices in the house are accounted for in the devices list, but I don’t know what the wlan0’s are.
Thanks in advance for the help.
Message 1 of 4
Accepted Solutions
wap1
Re: Unknown wlan0 devices on 2.4 ghz Orbi network
Message 3 of 4
All Replies
Guru
There a screen capture picture of this?
Where are you seeing this "wlan0" at? On the status page on the RBR, RBS or Orbi app?
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 4
wap1
Message 3 of 4
Guru
Please mark your thread as solved so others will know.
Enjoy.
Testing
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 215 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
