Reply
Uuuuummmm what? Amazon plug shows up as Satellite.
Intensified
So, I have something called AmazonPlug5JHQ as a satallite.  I am sure it is an Amazon smart plug, and it wouldn't be unreasonable for me to have missed setting up one of them when I changed my SSID, but any idea why it is showing up as a Satallite?  I don't think it is hurting anything, just curioius.Say what now?
AX6000 WiFi Mesh RBK854
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Accepted Solutions
Intensified
Re: Uuuuummmm what? Amazon plug shows up as Satellite.
Disregard, disappeared after a reboot.
Message 3 of 4
All Replies
Guru
Is this on the RBK50 or Orbi AX system?
Is this in the Orbi app and RBRs web page as well?
Can you attached the picture file using Choose FIle button on your post?
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 4
Intensified
Message 3 of 4
Guru
Enjoy. Smiley Wink
Testing
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 162 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
