Reply
V3.2.18.1-signed
DaytonaZ33
Star
Re: V3.2.18.1-signed
No offense, but on a device that costs $700 that has had a critical flaw for months now, it's not a good look when a Netgear employee comes in here and has no idea there is even a new firmware out.
Very glad I moved on from Orbi.
Message 26 of 75
Ace321
Apprentice
I don't beleive that is correct. I downloaded RBR750 firmware from your site and here is the file name in zip folder.
RBS750-V3.2.17.12_1.4.14-signed.chk
As you can see official firmware from NG support site also has "signed" at the end.
Message 27 of 75
vajim
Master
so will the real 'signed' firmware stand up
Message 28 of 75
Guru
I believe she's asking about the one thats not available on the download site and only being seen on some users RBR web page or the orbi app: V3.2.18.1-signed
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 29 of 75
PatrycjaG
NETGEAR Moderator
Hello @vajim,
You don't use it, but @Ace321 does Smiley Wink
If one of you could send me a screenshot of the proposed version 3.2.18.1-signed, I would be able to escalate the information to the technical support teams to check the information Smiley Happy
Have a nice day
Patrycja
Netgear Team
____
Cliquez sur KUDOS si ce post est utile et marquez le comme SOLUTION ACCEPTEE
Message 30 of 75
Mastra11
Apprentice
@ FURRYe38 but isn't everyone receiving this version? I received it but I haven't installed it yet, did you install it? thank you.
Message 31 of 75
Guru
I don't believe so. I checked mine and nothing comes up. I'm still on v12.
Testing
Message 32 of 75
Guru
I that NG has just posted v1 for the 8 series now on there download site.
Nothing up yet for the 7 series.
Testing
Message 33 of 75
Mastra11
Apprentice
@ FURRYe38 I have version 3.2.16.22 and it notified me the 3.2.18.1-signed update which I haven't installed yet. On the site I always see 3.2.17.12 as the latest version 3.2.18.1-signed no.
Message 34 of 75
Guru
NG hasn't put up anything more recent that v12 for the 7 series systems. The new v1 is only for the 8 series.
Testing
Message 35 of 75
Mastra11
Apprentice
@FURRYe38 what do you mean by series 7 and series 8? I do not understand.
Message 36 of 75
Guru
series 7 = 740/750 and series 8 = 840/850 orbi systems.
Testing
Message 37 of 75
Mastra11
Apprentice
@FURRYe38 ok i got it, thanks. I have RBK753 then series 7 with firmware 3.2.16.22 and it notified me version 3.2.18.1-signed
Message 38 of 75
vajim
Master
@Mastra11 wrote:
@FURRYe38ok i got it, thanks. I have RBK753 then series 7 with firmware 3.2.16.22 and it notified me version 3.2.18.1-signed
so the questions remain....
what is 3.2.18.1-signed?
why is it there and why does a NG moderator appear to NOT know of it?
Message 39 of 75
Guru
They maybe pushing notifications to the 7 series RBRs first. Up to you if you want to update or not. I would use the RBRs web page and web browser if you decide to do it.
Testing
Message 40 of 75
vajim
Master
Message 41 of 75
Mastra11
Apprentice
@FURRYe38 I received notification of the update on the ORBI app and also in the web GUI. I always update from the web GUI
Message 42 of 75
Guru
Same here.
Testing
Message 43 of 75
vajim
Master
Same here.
Message 44 of 75
Mastra11
Apprentice
@ FURRYe38 ok you have rbk850 and rbk750?
Message 45 of 75
Guru
Just the 850 series.
Testing
Message 46 of 75
Mastra11
Apprentice
@FURRYe38 OK thanks
Message 47 of 75
bullm00n
Apprentice
Showed up in both the WEB app and IOS app for me yesterday and I did the install last night.  No drama, but I did have to power cycle the modem / router / switch afterwards to get Internet back - seems common and I think that may have something to do with the LAG on the ports to the modem I have setup.  Otherwise, uneventful.
bullmoon
Xfinity / CM1150V / RBR850 / RBS850
Message 48 of 75
Zultan
Star
Very stable with 80+ devices and 5 satellites - RBR850 and RBS850s
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 49 of 75
Mastra11
Apprentice
@Zultan have you already installed the new firmware 3.2.18.1 and everything works fine? thank you
Message 50 of 75
Top Contributors
Discussion stats
  • 74 replies
  • 3079 views
  • 54 kudos
  • 14 in conversation
Announcements
Orbi WiFi 6E
