Orbi WiFi 7 RBE973
Reply
V4.6.8.2 performance issues?
preswors
Follower
I know we are all concerned with the RBK 853 Web access disappearing on V4.6.8.2 but has anyone also seen performance issues? WIFI speed tests are way off in the downstream direction even at MCS 9 and wired gives me a 500 Down and 940 up on a 2Gbps connection. Is anyone else seeing any issues?
Message 1 of 2
Guru
Re: V4.6.8.2 performance issues?
What Firmware version is currently loaded? Has the RBR or RBS been downgraded any?
What are your wired speed results look like?
What wireless devices are you using with the system?
Turn OFF the RBS and test with just the RBR alone.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Is Armor, SPC or Traffic Meter enabled?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 399 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
