Reply
Virgin V6 boxes since new orbi firmware
AlanLS
I have a ORBI WiFi 6 system with 2 satellites and 2 Virgin V6 boxes.  The Virgin boxes all worked well and communicated via wifi with each other allowing me to watch videos on one recorded on the other.  Until....  a recent firmware upgrade on the router.  So everything still connects individually and  I still have a good signal, but my virgin boxes won't talk to each other.  I have tried rebooting everything several times but it makes no difference.  Is there a new setting in the Orbi I need to adjust?  Any other advice.  Thanks
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 6
Accepted Solutions
Guru
Re: Virgin V6 boxes since new orbi firmware
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 6 of 6
All Replies
Guru
What Firmware version did you have loaded prior?
Testing
Message 2 of 6
AlanLS
Thank you for your interest.  My firmware is 3.2.16.22 which I loaded recently as it came as a recommende update in the app.I don't know what was there previously but it was the standard version which had worked well on all systems for several months.  I am on Virgin broadband and have superhub 3 running in modem mode which has worked fine since i bought the orbi.  I have done a reboot (from the app) of the system which probably isn't a factory reset.  how would I do that?
Thank you.
Message 3 of 6
Guru
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
IF this doe not resolve the problem you can downgrade the system to v6 which may have been what had been loaded previously.
https://community.netgear.com/t5/Orbi-AX/RBK-852-New-Firmware-Version-V3-2-16-6-1-4-4/m-p/1962430/hi...
Testing
Message 4 of 6
AlanLS
i found the solution.  Rather than just resetting the virgin boxes, I turned them completely off and took out the plug.  On restarting everything works fine.  Thanks again for your interest.  AlanLS
Message 5 of 6
Guru
Enjoy. Smiley Wink
Testing
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 403 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
