Reply
WTH!!! RAX120 = Crap then I buy Orbi AX6000 an now you cant separate wifi bands?
aonavy1
Guide
Please tell me Im missing something. You cant seperate 2.5 and 5ghz?im 15ft from my router and only a 5th of my speed because im on 2.4 right now
Message 1 of 6
Guru
Re: WTH!!! RAX120 = Crap then I buy Orbi AX6000 an now you separate wifi?
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 6
aonavy1
Guide
done
Message 3 of 6
CrimpOn
Guru
Actually, I think the RAX120 is a Nighthawk product, not an Orbi.
https://www.netgear.com/support/product/RAX120.aspx
I believe the forum for that product may be https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
The User Manual for the RAX120 talks about WiFi settings starting on page 75.
https://www.downloads.netgear.com/files/GDC/RAX120/RAX120_UM_EN.pdf
The implication is that 2.4G and 5G channels can have different SSID's.  (It doesn't show a screen shot, and I do not have one to look at.)
I love my Orbi.
Message 4 of 6
Guru
https://community.netgear.com/t5/Orbi-AX/WTH-RAX120-Crap-then-I-buy-Orbi-AX6000-an-now-you-cant-sepa...
Message 5 of 6
CrimpOn
Guru
Right again. I need to read more carefully.
I love my Orbi.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 554 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
