Reply
WTH!!! RAX120 = Crap then I buy Orbi AX6000 an now you cant separate wifi bands?
aonavy1
Guide
Please tell me Im missing something. You cant seperate 2.5 and 5ghz?im 15ft from my router and only a 5th of my speed because im on 2.4 right now
Message 1 of 4
Guru
Re: WTH!!! RAX120 = Crap then I buy Orbi AX6000 an now you cant separate wifi bands?
Orbi MESH systems don't support separation of SSIDs. MESH works differently then non MESH wifi routers. Mainly the wirelss backhaul.
It's also up to devices to connect to either frequency, Not Orbi.
You can help some of this.
Try turning down the power output of the 2.4ghz radio from 100% to 75 or 50%. under Advanced Tab/Advanced Settings/Wireless Settings
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
What devices are you using?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 4
aonavy1
Guide
turning that down will effect my 2.4 stuff thats further away. UHG! I mean it works better then the rax120 but it still I cant do this. I made my guest network my other entowrk for now,.
Message 3 of 4
Guru
Good luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 465 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
