Reply
What recommended cable modem for AX4200
UARK
I am wondering which cable modem that you all recommended for AX4200 mesh wifi system (cbale provider is COX). Welcome and appriacate for any suggestions. Thanks
Note: looking for DOCSIS3.1 with Gogablast
Message 1 of 6
Guru
Re: What recommended cable modem for AX4200
Netgear makes several devices that are Docsis 3.1 capable.
CM1000
CM1100
CM1200
CM2000
It all comes down to what you want. I wouldn't recommend the cm1200 just because it has 4x ethernet ports (cost extra for) and for most users, they can't use them. Reason why is that unless you have business class line or pay for multiple public ip address, you can only connect 1 device to the modem. Meaning the other ethernet ports are pointless. Both the cm1100 and cm1200 support port aggregation so ports 1 & 2 are useful if you're using that. but again, if you don't pay for the extra or have business class, ports 3/4 dont' do you any good.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 6
UARK
Thanks for the recomenedation.
I was thinking netgear CAX80, but it is unbelievable expensive. So, I think CM1100 is a good alterative choice.
By the way, CM2000 has not coming out yet, right? The official website said this product will be available around 9/24. So, I guess this is a new product, right?
Message 3 of 6
Guru
The CAX80 is a modem/router combo device.
the CM2000 has been released, it just sold out quickly. The CM2000 has a 2.5G ethernet port on it instead of using link aggregation like the cm1100 and cm1200.
Message 4 of 6
Mstrbig
Master
Arris SB8200 would be the fastest as it is DOCSIS 3.1 and has great specs.
Arris SB6190 would be a second choice. It is DOCSIS 3.0 and pretty much has the same specs as the SB8200.
So if you want to go with Netgear, choose one that fits those specs.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 5 of 6
Guru
NGs CM1000 thru 2000 are all D 3.1 modems. CAX80 is as well.
I would avoid the Arris 6190:
http://www.badmodems.com
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RBK752(v.5) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1761 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
