× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
Where to Send Bug Reports
tucsontico
Virtuoso
I recently upgraded to firmware V4.6.3.7_2.0.49. My overall review is the firmware seems to be fine. However, I have noted some oddities that appear to be bugs in the firmware, e.g., when using the web-base GUI, I can check "Remember this password" on the RBR but it will not save that in cache but the RBS will. Which forum or support area is the right place to report this to Netgear?
Message 1 of 4
Accepted Solutions
Guru
Re: Where to Send Bug Reports
I recommend sending forum moderators a PM:
@Blanca_O and @Christian_R
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
All Replies
Guru
Message 2 of 4
tucsontico
Virtuoso
Thanks. I'll send them my onservations.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 201 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
