Reply
Which additional satellite for RBK753
akhilstyle
Hi,
I have an RBK753 - 1 router and 2 satellites via Ethernet backhaul. I would like an additional satellite. Do I have to get an RBS750 or can I get something else that will integrate with my mesh system? So that I can use the orbi app with it etc.
An additional 750 satellite retails at about £250 so not sure If it’s worth me getting this or not?
Message 1 of 4
Accepted Solutions
Guru
Re: Which additional satellite for RBK753
RBS 7 or 8 series work.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 4
All Replies
Guru
Message 2 of 4
akhilstyle
Hi,
Thanks for your reply. 4000 square feet - however the internal walls are all brick so the signal can drop quite quickly.
The router is in the middle of the house. The 2 satellites are in 2 of the corners. Distance wise this is around 40ft. But they are both connected via Ethernet to the router.
Message 3 of 4
Guru
OK, ya brick will be a factor for sure.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 311 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
