Faz2000's avatar
Faz2000
Guide
May 29, 2022
Wifi drop-outs constantly
Watching this with interest.
I've just bought and installed the Orbi RBK750 setup and facing soul-crushing Wifi drop-outs constantly. At the moment I'm out the best part of $1000 and copping an absolute pasting from my wife and family because our network has stability regressed badly. I'll try the suggestions above and see if anything improves it.
I do wonder if maybe a  satellite is too close to the router - would this cause interference, or flip-flopping from one to the other?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    https://youtu.be/UR0viMLISz4
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Set 20/40Mhz Coexistence to 40Mhz only.
    • Faz2000's avatar
      Faz2000
      Guide
      Thanks for reply.
      I'm on Firmware Version V4.6.5.14_2.0.54 on the RBR, Firmware Version : V4.6.5.14 on the RBS.
      Modem is a Draytek Vigor 167 in Bridge Mode connected to VDSL FTTN NBN broadband connection. Connection is about 17Mbps UP/50Mbps DOWN and solid as a rock (it's not the internet cutting out).
      Home is... uhh... I guess 3500 square feet? Mostly on one level, two rooms downstairs. Timber. Big block.
      Satellite 1 is ~15 meters (3 rooms) away from router - it's connected via ethernet cable.
      Satellite 2 WAS downstairs (also via ethernet cable) but I have temporarily turned it off as I suspect this was a primary cause of the issue (Sat 2 and Router Wifi overlapping significantly). Whilst this is downstairs, I think it's only 4-5 meters away in a straight line (through a floor of course).
      Channels I've got 2.4Ghz using Channel 1, 5Ghz Channel 48.
      Minimal Wifi neighbours (I live semi-rural).
      The behaviour I have experienced is Wifi devices losing connect for 30 seconds to a few minutes, regularly (multiple times per hour). Streaming TV pauses and buffers - even plain old web-browsing grinds to a halt on (for eg) my iPad before it finds the connection again. Wired devices OK (or mostly OK) as far as I can tell.
      Last night I disabled Satellite 2, so will see if that changes the behaviour - one suspicion I have is that devices near or between the RBR and Sat 2 were getting confused the options and flipping between the two. Is this something other users have experienced? I can't seem to get a definitive answer on this even as a possible root cause of the symptoms - only "too much Wifi might cause problems". It would seem to be a re-creatable scenario.
      Only other thing I've done is reserved a few IP addresses for the Satellites themselves and selected wired devices that are always connected (printer, NAS, SONOS bridge, etc).
