- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi slow speed on AX6000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello , I have put 3 AX6000 on my network.
My service provider 1Gb, Speed test on LAN : 125Mb. on WIFI 19MB!
However, the satellites are connected to 1Gbs switches which are also connected to 1Gbs LAN.
On each switch where the satellites are connected, in LAN I have 120Mb in Wifi less than 20Mb.
I have try to reset factory, same pb: slow wifi connection, In 2.4 an 5GHz. My house is not big (under 100m²) And only 3 houses around me.
How can I do to increase the speed of the wifi?
Thanks.
C.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi slow speed on AX6000
The 1 Gb to 125 makes me curious if you test on the LAN in Gb/Mb (bits like carriers do) or MB as computers count data transfers.
Similar, for these 19 or 20 on WiFi - Mb/s or MB/s? Testing on your LAN or to the Internet?
Last but not least, what mobile WiFi clients are used? This is where o e would expect the big differences coming in after streamlining the units on a good set-up like yours.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this a Orbi system? If so, which model? AX6000 is not a model #
What CAT# LAN cable are you using?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Having too much wifi can also cause problems. For that size home you only need the RBR.
Thanks.
C.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I don't know why, but since this moorning, it's work well:
C.
- Mark as New
- Bookmark
- Subscribe
- Permalink
