Orbi WiFi 7 RBE973
Reply
Wired connections not working with Dynamic DNS
bpaskin
I have a weird connection issue that only happens with wired connections.  Wireless connections are fine.  I have a RBR850 router and RBS850 satellite, but I am only concerned about the router.  Both are running firmware V3.2.16.6.
I setup the router to update my DynDNS IP from the modem, and that works fine.  No issues with that.  However, when trying to access the DNS name through any wired computer does not work.  It does not matter if it is ssh, web browser, sftp, nothing workings.  Everything works fine using wireless.  Going directly to the IP Address of the machine works, as well.
I have several Linux, Mac machines, printer, and a NAS hooked into the router via a netgear 8 port switch.  Doing a nslookup of the DNS name fines it fine and has the correct IP Address.
This setup was working with my Nighthawk router.
Setup:
coax > modem > router
wired devices > switch > router
Thanks for any suggestions.  Brian
Message 1 of 12
Guru
Re: Wired connections not working with Dynamic DNS
Does directly connecting the PC to the back of the RBR change anything?
Message 2 of 12
bpaskin
Hi, thanks for the suggestion.  It is working directly, so it must be the switch somehow.  The interesting thing is that the switch (GS108E) works with the Nightwawk (R7800) fine.  I restested and not an issue.  So something about the Orbi doesn't like what is happening on the switch.
Brian
Message 3 of 12
Guru
The 108E is a smart managed switch. Manged switches are known to cause problems.
Try disabling IGMP protocols and any green ethernet features on this switch if they are accessible.
I can confirm the NGs GS 105/108v4 (non E version) switchs work with Orbi AX. Also D-Links DGS-105/108 and HP ProCurve 1400/1800 series work fine as well.
Message 4 of 12
Chuck_M
Mentor
To clarify, you are saying you cannot reach local (LAN) assets using the dynamic dns name (e.g. myhouse.ddns.net) -- but you can reach them when you are outside of the LAN?
Message 5 of 12
Mikey94025
Hero
Message 6 of 12
bpaskin
Yes, that is correct.
Message 7 of 12
bpaskin
Yeah, I ordered a new switch that is arriving today.
Message 8 of 12
Guru
Which model and mfr switch did you order?
Message 9 of 12
bpaskin
Netgear GS308 unmanaged switch.  It has arrived, I will replace the other one later this evening.
Brian
Message 10 of 12
bpaskin
New switch did not help.
Would anyone recommend a different switch that works with loopback witht the Orbi?
Brian
Message 11 of 12
Guru
Not sure if NG GS 1 series v4 will work in that regard. I do have mine set up with a segment thats daisy changed to my RBS. A 108 and two 105s then RBS...there a quick way I can check this to maybe help find out?
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 953 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
