- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
YouTube TV unable to determine location iOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
YouTube TV application on iOS devices not able to determine location. After much research and troubleshooting with YouTube TV support I have determined it works fine if I turn off the guest network. But, as soon as I enable the guest network YouTube TV goes back to not allowing live local channels due to not being able to determine location.
RBR850/RBS850 AX6000
Firmware:V4.6.3.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: YouTube TV unable to determine location iOS
Is the mobile device connected to the guest network when it's enabled or the main wifi SSID?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router SXK30(v.122) and R8500(v.158) Router Mode and Wired Backhaul | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Spectrum/Charter Technicolor Docsis 3.1 Voice Internet Cable Modem Model E31T2V1
It happens connected to either guest or main. There are several Apple devices in my home network ranging from iPhone 6 to 13 with various versions of iOS
Yes, multiple times.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Do you have Armor or Smart Parental Controls enabled?
How about factory reset of the RBR and RBS and setup from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No, I do not and have not ever run either of them
Was hoping not to have to do a factory reset. I have tons of home automation stuff that would need to be re-configured/setup. Smart thermostats, appliances, lights, outlets, door locks, air handlers, smoke detectors, dehumidifier, camera's, etc. It will take me hours to re do all that
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Make a backup config to file on the RBR of the current state:
Try a reset and before you load the backup config, test the guest network with youtube first, to see if there is any changes in behavior...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks, I will try that this coming weekend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have created a config backup. Any specific advice regarding the factory reset? Any gotchas? I plan to just log into the router and factory reset, leaving the satellite connected, and then go thru setup.
Once I reload the config file will all my previously registered devices automatically connect, or will I need to manually need to connect them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Don't enable Armor, Access Controls or Smart Parental Controls on Orbi App.
Just setup wifi config using same name and PW as before, sync RBS if needed. Your devices should auto reconnect once SSID name and PW is applied.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Did not get an opportunity to hard reset this past weekend. my wide needed the internet and I didn't want to risk a prolonged outage. Happy wife, happy life. LOL
