Orbi WiFi 7 RBE973
Reply
can not connect to VPN
dohc97
Follower
Just got my Orbi RBR750 last week. I can connect to vpn to login to my work using a wired connection.  when I am on a wifi connection, I can not connect to my vpn. A workaround I found is to connect to vpn first when I am on wired connection, unplug the wire, and connect to my wifi. I can not connect/disconnect and reconnect again to my vpn. Any settings I should check on the Orbi?
Message 1 of 2
Guru
Re: can not connect to VPN
Is the Orbi system operating in Router or AP mode?
Does this happen on your one device or others as well?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 354 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
