× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
iOS device cannot load the webpage in correct layout
ALEUNG
Last week I installed the RBK853 to replace my old Apple Airport extreme router. However, I found out that iOS cannot completely load the webpage in correctly layout. For example, the attached screen shot was what I had when loading ebay.com
I need to wait for several minutes or turn on/off the wifi several times then press reload so that I can see the correct layout.
However, I don't have such problem in Android device.
I have alreay checked byOrbi app and the firmware is alreay the most udated one. Could anybody help me to solve this problem?
Firmware ver. V3.2.16.22_1.4.9 (already click check update button and it is the latest version & I don't  want to install firmware manually)
Message 1 of 18
Accepted Solutions
Guru
Re: iOS device cannot load the webpage in correct layout
You can try inputting same DNS addresses on the RBRs web page, save and apply. Do a full reboot on the ONT and RBR, set the iphone back to Auto for DNS and check to see if the problem continues...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 18 of 18
All Replies
Guru
This the only web page that this happens?
Try a different device?
ebay loads fine for me on OSX 10.4.6 using Opera and iOS 14.4.1. I'm v12 FW.
Message 2 of 18
ALEUNG
This happened to amazon, ebay and several webpages. They cannot display the html correctly and even sometimes say safari cannot find the server. Then I need to turn off/on wifi to try again.
I experienced it in my iPhone 11 Pro Max(iOS 14.4.2) and my iPad Air (iOS 14.4.2). These 2 mobile decices worked fine uner my old router Apple Airport extreme.
My notebooks are working fine under Orbi.
Message 3 of 18
Guru
Poossible device issue if other devices are working thru Orbi.
Message 4 of 18
ALEUNG
I only know the ONT is Huawei provided by my ISP. Not sure the model number
Message 5 of 18
Guru
Hmmm. Ok
You can look at the RBRs Advanced Tab Home page and look under the Internet section and see if there is a ##.##.###.### address or a 192. or 172 or maybe a 10 IP address displayed there? If you see any of these 3 IPs listed, there maybe a router at the ONT.
Message 6 of 18
ALEUNG
Do you mean the following Internet port section?
Message 7 of 18
Guru
You don't need to show it as I would not post the IP address here in a public forum. Just look as see if there is any of those listed and let us know. If you see the ##.##.###.### address then this would be a public IP address and thats good. Means there is not router or they configured the ONT to pass the Public IP address to the RBR.
Message 8 of 18
ALEUNG
Problem was resolved after I had manually inputted Google public DNS 8.8.8.8 and 8.8.8.4 in iPad/iPhone network setting
Message 9 of 18
Guru
And if you remove that setting does the iphone not work again?
Message 10 of 18
ALEUNG
Correct. If I changed the DNS to auto (192.168.1.1), App like IMDB loaded a long time and webpage also need longer time to display in correct format in my iOS devices.
No impact to Windows and Android devices......
I found the solution in this community. Any idea why it only happened to iOS devices?
Message 11 of 18
Guru
What IOS version are you using? Im using 14.4.2 currently. I've not had to set DNS manually on my iphone.
Did we ever establish what our RBR is getting for a IP address on it's internet port?
Message 12 of 18
Guru
Ya I see the picture was approved.
Next time, please edit out the Internet IP address for public forum review. That doesn't need to be posted.
Message 13 of 18
ALEUNG
My iPhone and iPad are also using iOS 14.4.2.
I confirmed getting public ip address from my ISP ONT
Message 14 of 18
Guru
But only happens on the Iphone?
Message 15 of 18
Guru
What DNS settings are you using on the RBR? Auto or custom?
Message 16 of 18
ALEUNG
It happens only in iPhone. So I only manually inputted 8.8.8.8 in iPhone/iPad Network setting. I didn't change anything in the RBR850 and other devices such as Notebook, Android tablet etc.......
Message 17 of 18
Guru
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 571 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
