Reply
orbi 850 dropping
HomeUserguy
orbi 850 dropping
I have on the latest firmeware and my wifi drops multiple times per day.  I know its not a device as my alart drops to cell, my phone drops, and PCs loose connection. I cant find anything in the logs saying that status. based on the wifi singal going down on a PC it would not appear to be the provider.  It typically drops for about 30 sec -1min and comes back.
Are there any know issues with the V4.6.3.16_2.0.51 firmware and better logs?
Message 1 of 4
Guru
Re: orbi 850 dropping
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try disabling AX mode on the RBR
Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a full reset and setup from scratch been performed?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 4
striker69
Star
I Would Try Running In The AP Mode. I Had A Similar Problem.
Message 3 of 4
Guru
Would be kind of hard to run AP mode if the OP doesn't have host router in front of the RBR.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 318 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
