Reply
orbi router
dolimite
orbi router
I HAVE AN RK752 ORBI ROUTER WITH PARENTAL CONTROLS.  I RESET IT TO FACTORY SETTINGS.  DELETED 2 OR 3 PROFILES UNDER PARENTAL CONTROLS.  I CANNOT DELETE THE 3RD PROFILE WHEN PARENTAL CONTRLS ARE TURNED BACK ON.
IT SAYS UNABLE TO DELETE PROFILE.
ANY IDEAS?
Message 1 of 2
Guru
Re: orbi router
Netgear has set up a community forum specifically for the Smart Parental Controls product. Most of the people who watch that forum are more likely to have experience with these controls and know how to work it better than those of us who follow this  forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
https://www.netgear.com/home/services/smart-parental-controls/
Please STOP yelling. We can hear you.
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
https://kb.netgear.com/000062988/Why-can-t-I-see-the-NETGEAR-Smart-Parental-Controls-tile-in-the-Orb...
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NOTICE-Live-Parental-Control-Service-based-o...
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 157 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
