Orbi WiFi 7 RBE973
Reply
orbi wifi 6 RBR750
juju70
Follower
orbi wifi 6 RBR750
Why can't i get the satellites to connect.  One connects and the other will not.  The wifi also shows as unsecured on the iphones.  I am at the point of taking apart and returning because this is just not worth the hassle.
Message 1 of 2
Guru
Re: orbi wifi 6 RBR750
What Firmware version is currently loaded? Be sure the RBS are loaded with same version of FW as the RBR.
Is the Orbi system operating in Router or AP mode?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 902 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
