Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rbr50 vs rbk752
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-07-08
07:04 PM
2021-07-08
07:04 PM
rbr50 vs rbk752
What are the comparisions between a RBK752 and a RBR50? is it worth it?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-07-08
10:40 PM
2021-07-08
10:40 PM
Re: rbr50 vs rbk752
Hi @sgtgchjr,
Here are the links and tech specs so that you can compare them:
RBK50: stable and has been in the market for a few years now
https://www.netgear.com/home/wifi/mesh/rbk50/
- WiFi Coverage : 5,000 sq. ft.
- Orbi Router (AC3000) : Six (6) high performance internal antennas with high-powered amplifiers. Implicit & Explicit Beamforming for 2.4GHz & 5GHz bands. MU-MIMO capable for simultaneous data streaming to multiple devices. Powerful Quad-Core 710MHz processor.
- AC3000 Tri-Band WiFi : (1,733+866+400Mbps)†
- Ports : Four (4) 10/100/1000Mbps Gigabit Ethernet ports. One (1) WAN & three (3) LAN
- Memory : 512MB NAND flash and 512MB RAM
- Security : Comprehensive anti-virus & data theft protection for your PC, Mac® and mobile devices with NETGEAR Armor™. Standards-based WiFi Security (802.11i, 128-bit AES encryption with PSK). Guest WiFi network is easy to setup separate & secure Internet access for guests. Works with Amazon Alexa & the Google Assistant
RBK752: much more faster and good for future proofing your home
https://www.netgear.com/home/wifi/mesh/rbk752/
- Orbi Router (AX4200): : Six (6) high performance internal antennas with high-powered amplifiers
- Beamforming : Implicit & Explicit Beamforming for 2.4GHz & 5GHz bands. MU-MIMO capable for simultaneous data streaming to multiple devices
- Processor : Powerful Quad-Core 1.4GHz processor
- AX4200 Tri-Band WiFi : 2.4GHz (600Mbps†) + 5GHz (1200Mbps†) for WiFi devices to connect to the Internet. 5GHz (2400Mbps†) dedicated WiFi link for faster data connections between Orbi Router and Orbi Satellite
- Ports : One (1) WAN port and 3 LAN Gigabit Ethernet ports
- Memory : 512MB NAND Flash and 1GB RAM
- Works with Amazon Alex and the Google Assistant : Yes
- Security : Comprehensive anti-virus & data theft protection for your PC, Mac® and mobile devices with NETGEAR Armor™. Standards-based WiFi Security (802.11i, 128-bit AES encryption with PSK). Guest WiFi Network is easy to setup separate & secure Internet access for guests
Hope this helps.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-07-09
06:16 AM
2021-07-09
06:16 AM
Re: rbr50 vs rbk752
do you have the RBK50 already?
Do you have quite a few AX devices?
I have an AX mesh system and the RBR50 system and the only times I see much difference is on my AX devices when I'm close to it.
Message 3 of 3
Announcements
