Reply
rbr750
kristopherleej
rbr750
Greetings, one of the satelites is shown offline. It has been in the same room of the house for about 8 months. I unplugged it for several minutes and plugged it back in and it still did not connect. I did a re-boot on the router for the system and let everything sync up again and it still didnt connect. What else can I try?
Message 1 of 7
kristopherleej
Re: rbr750
I also made sure the firmware was up to date.
Message 2 of 7
Guru
Re: rbr750
Try syncing the RBS while in same room as RBR?
Swap Locations with the other RBS?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 3 of 7
kristopherleej
Re: rbr750
thanks, about 3000 sq ft. The RBS and RBR are both on the 2nd floor about 25ft away (2 rooms over) RBS is in a bedroom (office) and the RFR is in the family room. I tried bringing the RBS into the same room to sync, not sure if I am syncing correctly. I press the sync button on both and hold or release quickly?
Message 4 of 7
Guru
Re: rbr750
Press once fully then release...
Last resort,
Factory reset the RBR and RBS. when you see the front pulsating WHITE, Power OFF for 2 minutes on the RBR and RBS. Leave the RBS OFF. Walk thru the setup wizard on the RBR using a wired PC and web browser. Check internet access with the RBR only. Wired and wireless.
When the RBR is back to ready, use the sync buttons on the RBS and RBR to sync the RBS. I would do this with the RBS in same room as teh RBR. 10 feet distance.
Message 5 of 7
kristopherleej
Re: rbr750
Tried that and it is still not syncing. I have another RBS downstairs and is has not lost connection.
Message 6 of 7
Guru
Re: rbr750
I recommend you contact NG support and let them know what or having problems with.
You can open a support ticket here:
https://www.netgear.com/support/#
@DarrenM @ChristineT
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 140 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
