Orbi WiFi 7 RBE973
Reply
satelite Ethernet cable connection speed
kknox14
Follower
What speed should i get through the  ethernet port on a satelite.    200 meg  service    Orbi  AX4200
Thanks
Message 1 of 4
Guru
Re: satelite Ethernet cable connection speed
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 2 of 4
Guru
Depends on what you connect to the RBS and it's design and support for speed and distances between the RBR and RBS.
Message 3 of 4
Guru
Any progress on this?
Thanks
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 500 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
