- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
service unreachable AX 4200 RBS750
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
wanted to update fw to the latest version available this week.
on the orbilogin page, the manual update box lists two of three satelittes status as unreachable - it also does not list the satellites as RBS750.
any thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: service unreachable AX 4200 RBS750
Possible the NG update service is down. We don't get that kind of info though here.
You can manually install if you like:
- Mark as New
- Bookmark
- Subscribe
- Permalink
current fw is v4.6.3.16
spectrum - Hitron E31N2V1
strange that the Orbi app lists the satellites but the orbi login.com does not
- Mark as New
- Bookmark
- Subscribe
- Permalink
will the update take if the Orbi login page does not recognize the sattelite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the RBS seen on the RBRs connected clients page? If they are, then use the IP address given to them to access the RBS web page and send the FW file there. Update the RBS first, then RBR lastly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the RBS IP address is listed and I plugged that number into two different browsers and it could not be reached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even if you bring the RBS 1 at a time to same room as the RBR and connect them wirelessly, you can't reach there web pages?
- Mark as New
- Bookmark
- Subscribe
- Permalink
have not tried that - to bring each one closer to the router to reach the IP address for the satellite -
if i do a factory reset on the satellites - can i update to the latest firmware? assuming that after the reset, the satellite will be recognized.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes...Reset maybe needed here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what are the steps for factory reset and re sync to the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Either press the reset button for 15 seconds on the back of the RBR or RBS. Another way for the RBR is to reset the RBR using the ERASE button on the RBRs web page under Advanced tab/Admin/Backup
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Access Controls, QoS or Traffic Meter on the RBR.
https://www.youtube.com/watch?v=cMw4ePACgc4
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you! i reset and it the model number is now showing up in the orbilogin.com!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Once it's all updated, I recommend powering OFF the ISP Modem, RBR and RBS for a good full minute or more, then back in with the modem, then RBR then RBS.
Please mark your thread as solved so others will know.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks for reminding me to power off - i updated the fw yesterday and forgot to do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
