Orbi WiFi 7 RBE973
Reply
EasyMESH support for Orbi RBK352
skaiwoka
Hi
I am buying Orbi RBK352 AX1800 wifi mesh and I noticed that it is not certificated for "EasyMesh" support.
Will be in the future with a firmware upgrade?
Or is the Nighthawk MK62 the only wifi mesh from Netgear with EasyMesh support?
thank you
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Accepted Solutions
Guru
Re: EasyMESH support for Orbi RBK352
@FURRYe38 is correct.
the NIghthawk mesh is netgears easymesh solution.
the Orbi line is their own unique setup for mesh.
I believe both the 60 and 80 series of MK support easymesh
Message 3 of 3
All Replies
Guru
I believe thats a Nighthawk MESH feature only.
Something to ask NG support about though...
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 834 views
  • 6 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
