- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No wifi from RBR850 or satellite. Satellite is solid magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset the RBR and RBS. when you see the front pulsating WHITE, Power OFF for 2 minutes on the RBR and RBS. Leave the RBS OFF. Walk thru the setup wizard on the RBR using a wired PC and web browser. Check internet access with the RBR only. Wired and wireless.
When the RBR is back to ready, use the sync buttons on the RBS and RBR to sync the RBS. I would do this with the RBS in same room as teh RBR. 10 feet distance.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No wifi from RBR850 or satellite. Satellite is solid magenta
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good.
Enjoy.
