Reply
Orbi Satellite permanently pinging the gateway
bpalob
Tutor
First of all, I am using the Orbi RBR750 system, which I didn´t find in the Model Listing for this forum.
The FW in use is V3.2.16.22_1.4.9.
I found a thread about the same issue, which seems to be closed but inconclusive.
For some reason I started monitoring my LAN traffic by mirroring interfaces on a switch to which the ORBI is connected.
My Orbi Satellite is constantly pinging the Orbi Router (Satellite 10.3.8.3 - Router 10.3.8.1). Every 2 seconds one ping. All day long.
Is this really intended bahaviour? This constant icmp traffic somehow disturbs me.
Message 1 of 9
Guru
Re: Orbi Satellite permanently pinging the gateway
I would presume so as there is a status report and detection happening with in the system and maintaining the connection between the units. If something happens then the status changes and thus the front LED will give indication of this. All this and other things rely on this design. Something to ask NG support about for more information.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 9
Bingoig11
Star
Have this kind of issue with the Mesh Nighthawk, except that the satellite is pinging a netgear website every second...
Case opened with Netgear, abnormal behaviour, waiting for a new firmware to be published (no ETA).
Message 3 of 9
Guru
What FW are you using?
Message 4 of 9
Bingoig11
Star
FW version is V1.0.6.110_2.0.49
Netgear support closed the case saying that the issue is identified and should be resolved in the next firmware.
Message 5 of 9
Guru
What model Orbi do you have?
Message 6 of 9
Bingoig11
Star
As stated in my first reply, I'm facing similar issue with the Mesh Nighthawk system, not Orbi Smiley Happy
Message 7 of 9
Guru
Well I believe these two systems are different. I would recommend that you post over in the NH Mesh forum for that. Maybe similar problem not really not the same nor are these systems the same.
Good Luck.
Message 8 of 9
Guru
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 263 views
  • 0 kudos
  • 3 in conversation
Announcements
