- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 and Amazon Alexa and Cisco IP phone
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I have had my Orbi for months now with a Bose soundbar 700 with Alexa and an Amazon Alexa Show. I also have a Cisco IP phone connected to work via vpn. Everything has worked wonderfully for 6 months plus and a week or so ago my phone constantly reregisters, my show will not respond, and my Bose has had to be reconfigured many times after losing Alexa control. Anyone else see this just pop up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 and Amazon Alexa and Cisco IP phone
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will try your ideas one at a time to see if one may work.
Again nothing in my environment has changed. Firmware was on auto update so that could have changed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can manually update to v12 at somepoint as well:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am updating the firmware mannually today then will monitor. A frustrating situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd probably do a factory reset and setup from scratch after the update if the problem continues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The test was short lived. The issues are still present. Will have to wait for the weekend when computers are not in use to start from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So this is odd(actually not odd at all). With the updated firmware I changed the default channels on the 5 and 2.4 wireless. I think I picked 44 and 11. My ip Cisco phone would not register at all. I put the channels back to default and everything is working so far. I guess I should have done what I said I would do and only change one thing at a time. I will monitor today working from home. Thanks again for your suggestions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What channels are you using now?
I recommend setting channel 40 on 5Ghz. 36 should not be used...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using the default of 48 on 5ghz. Auto on 2.4. I tried 44 and 11 which was bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, keep us posted...
