Backis
Sep 22, 2021Follower
Range of an Orbi AX200 ?
Hello, I wonder if anyone out there can help me with a simple question. I have 2 houses separated with 60 yards. Houses are wooden (no concrete) and between is simply air (no trees/rocks etc). Would it be possible to have the Router in one hosue and the Satellite in the other and they will be able to "talk" to each other or is the distance (60 yards) simply too long ??
I will bye the Orbi AX200 system with one Router and one Satellite
Any hints appreciated.
/Per
1 Reply
As plemans mentioned:
You can try it but it might be to far. we can't say exactly if it'll work because of how much the exteriors walls plus the distance will degrade the signal.
Will it connect? Maybe?
Will it connect fast enough to function? maybe?
Its tough for us to say that it'll connect without problems without actually trying it.
options?
1. buy the setup from a place with a generous return policy and return it if it doesn't.
2. burying an underground rated ethernet cable (best option). Even if you don't go with orbi, it'll allow connection between the 2. And isn't that expensive if you do it your self.
3. Check into a point to point system like netgear airbridge. That'd allow you to connect the 2"
