Reply
Satellites dropping WIfi constantly. RBR750
netblokeusa
I have gone through these forums looking for a solution....was sugegsted reposting in this sub forum...
So I use Xfinity.
My Cable modem is an Arris SB8200.
Orbi Router is RBR750 (purchased through Costco if that makes a difference)
Firmware Version
V3.2.18.1_1.4.14
It seems that my WiFi is a sporidically dropping (and has been for some undetermined time frame, it may be when I upgraded the Cable Modem a few months ago)
I never notice anything connected to the main router dropping but from satelites it dropps constantly.
Netgear support wants to charge me for the fix. they say it is some setting I have incorrect. I can't really afford to drop $90 for a new support contract.
Any ideas on what I need to alter?
Message 1 of 2
Guru
Re: Satellites dropping WIfi constantly. RBR750
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 182 views
  • 0 kudos
  • 2 in conversation
Announcements
