× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
970's 6E Broadcast Issues
Jc226
Tutor
Any update on this? I have been dealing with the disconnects and feel like they don't have the proper support for this
Message 1 of 3
Guru
Re: 970's 6E Broadcast Issues
What disconnects are you seeing.
Please give more details.
What devices do you all have connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Armor, Smart Parental Controls or Circle, Traffic Meter.
Is 240Mhz enabled Under Advanced Tab/Advanced Settings/Wireless Settings?
Message 2 of 3
Guru
Any progress on this?
FYI:
https://community.netgear.com/t5/Orbi-WiFi-7-BE-Mesh-Systems/New-RBE970-RBE971-Firmware-Version-9-10...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 380 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
