× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Anyone received theirs yet?
mgdurand1
Luminary
I ask because I took the plunge Tuesday as soon as the email hit my mailbox.  Paid for expedited shipping with expected delivery date (but not guaranteed) of today.  Fed-X 1 day shipping "once shipped".
Nothing today.  Called and inquired and they said should be out and on its way today and arriving tomorrow.
A check of the order shows still in the warehouse at 2:44 pm today (9/20/23)..
I feel that when I pay $2,500.00 for a product as well as expedited shipping then actual shipment should be a bit more accurate than so far.
Hence my curiosity as to whether anyone has received their WiFi 7 Orbi system yet.
Message 1 of 10
Accepted Solutions
mgdurand1
Luminary
Re: Anyone received theirs yet?
Well, at 4:55 pm got a note from Netgear that my order would arrive tomorrow morning by Fed-X.  Thanks!
Message 2 of 10
All Replies
mgdurand1
Luminary
Message 2 of 10
SoMoney
Tutor
Mine showed up a couple of days ago.   1st impression were "I can't believe how heavy the box is", this cant be my wireless router...
Sure enough, there was a Netgear sticker on the box so I opened it up and found the packaging was pretty well thought out.  Not Apple quality but definitely influenced by...
Setup was a bit of a PITA when the app connected to the router yet told me It couldnt configure it.  😕
About 5 power cycles later (Dont bump the power plug its janky), I finally got my phone to configure and update the router.
Good luck, I'll pray for you...
Message 3 of 10
Guru
About 5 power cycles later (Dont bump the power plug its janky), <What does this mean?
Message 4 of 10
SoMoney
Tutor
About 5 power cycles later (Don't bump the power plug its janky), <What does this mean?
   The 1st word that came to mind when seeing this behavior was I lot more descriptive but not suitable for young ears.    Netgear ORBI uses an unusually wide DC Power Barrel adapter(Old Dell Laptops Had this issue until they added a center pin to stabilize and ensure constant 20vdc -/+ connection).   I discovered that twisting, tilting, picking up, or pretty much moving either ORBI unit to add ethernet or check power/link status was causing the units to briefly lose connectivity and power cycle.   I guess you could call it faulty but as long as you treat the ORBI like a delicate expensive crystal baby you're fine...
Message 5 of 10
Guru
Thanks for the clarification.
Message 6 of 10
mgdurand1
Luminary
Mine made it in and the install was really simple: much easier than I thought it would be.  One caveat: I tried using the app and it was a bust.  Used the web and went much smoother.  The router and two sats perform as well and in certain instances better than my previous WiFi 6 system with 5 sats  Most pleasant discovery is the performance with my Ring doorbell system.  Ring 3+ and 4 cams.  Ring doorbell previously pretty much stayed at 60 RSSI no matter where I placed a sat.  Even tried next to the window right by the outside doorbell.  No joy.  The new system hooks in at 42 or so and stays there for the better part of 4 days so far.  An occasional 55 (once actually) but generally much better results.  So yes, pricey, but hell ... I'm 71 and deserve a treat every now and then <g>.  For me worth the price (at least so far - may still engender crotchety phase in the future, of course).
Message 7 of 10
farmrt88
Star
Thanks for the summary.  Regarding the Ring 3 Plus Doorbell and Ring Cameras - are these connected to 2.4Ghz or 5.0Ghz with better performance, and what was the previous WIFI system before the Orbi 970?
Thanks!
Message 8 of 10
schumaku
Guru
Unusually wide? Isn't this the same narrow, but certainly not small AC power adapter as coming with other bigger Netgear devices:
Model : AD2003F10
SKU: 216292
Part Number: AD2003F10
NETGEAR AD2003F10 AC Adapter
Yes, I could understand why these bricks are (under some conditions) nor ideal. I would prefer something with a simple (detachable) power cord on the AC side, However, it appears cost is a major factor in the design here.
Message 9 of 10
Guru
Not the same Power Supply.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 4169 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
