FURRYe38's avatar
New - RBE970 / RBE971 Firmware Version 9.10.2.3 Released
Enhancements: 12/04/2023
  • Various WiFi stability improvements
  • Various system stability improvements
Bug Fixes:
  • Fixes an issue where the satellite cannot reconnect to the router after a firmware update.
  • Fixes an issue where a Google Pixel 8 Pro phone causes system instability.
  • Fixes an issue where the router LED lights solid white even though the Internet connection is up.
  • Fixes an issue where the router web interface is not accessible after you reset the router to factory defaults.
  • Fixes various minor bugs.
Download Link:
https://www.netgear.com/support/product/rbe972s#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE971.aspx#docs.
IF MANUALLY UPDATING THE SYSTEM:
Be sure to update the RBS FIRST, then the RBR lastly.
Please navigate to the link below for step-by-step instructions on how to update your RBR971/RBS970:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS.
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
FW UPDATE ALL Feature:
If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place.
Quick Installation Guide, User Manual and Spec Sheet is here:
https://www.netgear.com/support/product/rbe971#docs
This article applies to:
Let us know how it works for you...
