NG7856
Oct 27, 2024Guide
power supply for orbi 970 110v/60hz - 220v/50hz?
I have older NETGEAR routers and extenders. The power supply for these units are all label 110v/60hz /220v/50hz.
I am assuming that the ORBI 970 can work on both electrical system with just a plug converter.
I found one on Reddit that was
Orbi 970 RBKE973 Power Supply
Genuine OEM Netgear Ac adapter that had adapters and worked on both voltages but where can I get it?
Is this the standard power supply for the ORBI 970 and satellites?
Is this correct?
Amazon carries a product advertised specifically for the 970 product.
According to the User Guide, the power supply should be 19V/3.16 Amps for both the router and satellites.
- NG7856Guide
The world has gotten smaller and many times people move for country to country or for other reasons need a new power supply. I have seen Netgear OEM power supplies pictures in a separate box on the net but I do not know where to buy a Netgear OEM power supply.
The Netgear OEM is small and compact. Other power supplies that work with Netgear are larger with too much cord.
