- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CBK752 Bufferbloat
- Mark as New
- Bookmark
- Subscribe
- Permalink
CBK752 Bufferbloat
Just wanted to know if anyone else was having crippling Bufferbloat with their CBK752 modem / router. Causing me huge latency and very unstable streaming (twitch), have tried everything I could but seems pretty hopeless. Guessing it's a firmware issue? Can't seem to get the hidden qos page to do anything, and have tried a factory reset with no speed test to try to turn off all qos but to no avail
Cheers,
Richard
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CBK752 Bufferbloat
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Didn't know your having problems on wired connections.
How is your device connected? Does this device have a ethernet port?
Be sure your using good quality LAN cable. CAT6 is recommended.
Test streaming and video with a wired PC or laptop to compare results...
