- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CBR40 - Blinking UPL blue light
- Mark as New
- Bookmark
- Subscribe
- Permalink
My CBR40 started blinking blue light for UPL yesterday. I shut everything down but can't get the light from blinking. Had this cable/routerfor 6 month and this is first the light blinking.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would have the ISP check there logs and signal to the modem. Give them any info from the CBR40's modem logs as well if needed.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CBR40 - Blinking UPL blue light
UPL?
What FW is currently loaded?
Who is your ISP service?
Are wired connections ok with internet? Wireless working as well? Or is everything not working?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPL: Blinking blue. The cable modem router is scanning for an upstream channel.
- Got lastest FW.
- Xfinity/Comcast.
- Internet speed for wired and/or Wireless is ok.
- Size of home is 1200 SQFT.
- Using channel 1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Xfinity came today and replaced adapter on the pole, and everything ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome. Glad they fixed it.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most likely you had noise on upstream and when INTERNET LED IS SOLID and US blinks, it typically means it in PARTIAL SERVICE state with one or more UPSTREAMS BEING IMPAIRED.
