Orbi WiFi 7 RBE973
Reply
Cbr40
Steakribeye
Follower
Cbr40
I tried activating the cbr40 already and Spectrum says my CBR 40 is active as I contacted them but the internet still doesn’t work, no blinking lights, four solid blue lights on and there’s a purple light emitting on the top ...are they purposely saying that so I don’t use it?? I need help I have gave them the Mac id and everything already too
Message 1 of 4
Guru
Re: Cbr40
Power OFF the CBR for 30 seconds then power back on. Ensure the RG6 cable is fully seating on it's jack.
You should have a wired PC connected one of the LAN ports in back.
Ask the ISP to check status from there side.
Ensure your PC is set for auto obtain IP addressing from the CBR40.
I presume you can connect to the CBR's web page?
Message 2 of 4
Blanca_O
NETGEAR Moderator
Re: Cbr40
Hi @Steakribeye
Welcome to NETGEAR Community!
If you have the Internet (planet-like) icon lit blue then it is an indicator that the cable modem router is online. How do you check if it is online? Is it via wired or wireless? Please wired a computer to the cable modem and access this page https://activate.spectrum.net/
Blanca
Community Team
Message 3 of 4
Guru
Re: Cbr40
Any update or progess on this?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1470 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
