Reply
Compatibility Question
MooseW31
Follower
Please disregard the model listed. It wouldn't take either of mine in so I put RBS40 in so I could post this.
I have an Orbi CBR750 cable modem/router. Will an RBS20 satelitte work with that? I have an RBS20 that I can't get to sync no matter what I try.
Thanks in advance!
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 3
Guru
Re: Compatibility Question
No. the RBS20 is not compatible with the CBR750
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 3
Guru
Be sure to visit the Orbi with Cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
You can ethernet connect the RBS to the CBR is all.
Thanks in advance!
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 3
Discussion stats
  • 2 replies
  • 161 views
  • 0 kudos
  • 3 in conversation
Announcements
