Orbi WiFi 7 RBE973
Reply
If you update the firmware, it is not compdate the firmware, it is not compatible with the product.
Heum
Follower
If you update the firmware, it is not compatible with the product. My product is Orbi RBK50 and I am using firmware V1.8.0.6. The configuration is RBK50 + RBS50 * 1EA RBW30 * 2EA is being used. In Admin mode, only Satellites 1Ea are displayed. Let me know how to fix it.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Guru
Re: If you update the firmware, it is not compdate the firmware, it is not compatible with the produ
First download the following version of FW: https://www.netgear.com/support/product/RBK50.aspx#download
Version 2.0.0.74 and
Version 2.2.1.210
For both router and satellite.
While the satelite(s) are connected to the Orbi router, manually update the satellites first with the v20074 version. Once that has been applied, load the v20074 on to the Orbi router. Let the system come back online.
Once the syetem is back online, load the v210 FW on to the satellite(s) first, then after, load on to the Orbi router.
After than you should be up to date on the entire system.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 895 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
