- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Multiple IP addresses for CBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I was hoping someone could help me out with a connection issue. I have two PC's at home. One is my personal PC and everything seems to be working fine with the CBR40 (I previously had an xfinity modum/router). However, my work PC won't connect via the internet or with VPN. I tried resetting the IP address with the command prompt and rebooting but that didn't work. I also remember seeing an IP address conflict message appear when I first set up the CBR40 but I didn't understand what to do with that message.
Any ideas on how to get my VPN and internet connection working for my work PC?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Multiple IP addresses for CBR40
Try setting up an IP address reservations for your devices under Advanced Tab/Setup/LAN setup. After you Add and Save, the CBR should reboot, reboot your devices during this time frame as well.
Make sure your devices are not using any pre configured static IP addresses ON the devices as well.
